Since the cage is complete, it is tear down time.
I had forgotten to photo the steering column support before installing the hood, so here it is. The actual support is so strong, I can stand all my 220 ponds on it without flexing. Should make for a solid steering feel, and is set up so that a steering column upgrade can be made in the future without needing to alter this mount.
Next is to totally pull it apart.
A few shots of the rear support that configures it's way around the battery and spare tire well to pick up the transaxle frame horns, ties into the roll cage and rear bumper. This is before final welding.
After building several buggy's and not liking the body fitment around the front Napoleons Hat area, I make a "rain lip" to help seal up the front. The original German design in this area used a lip that hung down on the body and shielded the seal here. So, once Brian installs the body for the last time, he can use some sealant here and have a really good air and water tight seal for those times he gets caught out in the weather.
The cage sitting on the bare chassis to show how it all ties together.
I use quick release pins for the rear bumper to make it easy to remove. Pop a 2-pin weather tight connector for the license plate light, pull 4 pins and the rear bumper slides off. Makes it quick and easy. 30 seconds off and 30 seconds back on. Drill through the bumper tubeing and the inner welded sleeve for a smooth looking fitment.
Right before I pulled the buggy apart, I asked Brian if he had thought about amber fog lights. So I mocked up a set of yellow painted cardboard to get an idea of where to weld on light tabs.
Used some square tubing to hold in place to tack, and then weld the light tabs.
Finished welding on the bumpers and cage, dress up work. (notice the personal protection of the lungs and ears. you only get one life, protect it)
Seat Belt tabs welded on the cage.
Cage and bumpers completed and ready for coatings.
Chassis on hillbilly rotisserie ready for final welding.
Cage and another chassis loaded up and going to the powder coater.
Then the bumpers, and another original Manx bumper loaded up and going to the Chrome Shop. Blingity Bling!
