Guys, please take the forum out of the frame
73SpeedBuggy
Post by 73SpeedBuggy »
Ok, having the forum appear inside the fram of the manxclub website makes the forum to small and his highly annoying. Please have the "Forums" link pop up a new window dedicated to just the forum.
Forum in a Frame
Interesting, the new format is the same size as the old format. Actually the page has more useable verticle display area than before. It is just set off to the side by removing the black strip down the right side.
vreuther
Post by vreuther »
As a work around, you should be able to open this link in a new tab or new window and not have dual scroll bars. http://www.manxclub.com/forum/index.php
73SpeedBuggy
Thanks vreuther, That works great.
CairoManx
Post by CairoManx »
Another problem with the double frame is the address in the window at the top never changes, depite what you look at on the Forum. So if you want to cut and paste a hyperlink to help someone who is looking for something, you have to use the work around that Vreuther posted to see the correct address.
