1776 Engine
FulsGld
1776 Engine
Post by FulsGld »
Hey All; We think we have a 1776 engine. We're going to tear it apart (cracked case) and throw another case at it. Does a 1776 require any machine work on the case or heads for the larger barrels? We're going to get a 1600dp shortblock today and would just like to transfer everything from the barrels on up from the old engine over to the new case.
Gary Berry
Prosser, WA
1971 Turista
1969 ManxVair
Member #1112
theManiac
Post by theManiac »
The case will have to be opened up for the larger 90.5mm cylinders. The stock cylinder heads will have to be opened up too. Other than that, everything else should be the same.
FulsGld
Post by FulsGld »
Hey Maniac; Thanks for the info. Looks like we will have to find someplace up here that can machine the case.
Gary Berry
Prosser, WA
1971 Turista
1969 ManxVair
Member #1112
FulsGld
Post by FulsGld »
One more thing, what are the differences between the T-1 case and the t-3 case? Can I use a t-3 case and swap everything over if I can get one for nothing??
Gary Berry
Prosser, WA
1971 Turista
1969 ManxVair
Member #1112
Post by manxdavid »
Sure, they're the same castings, the only significant difference being T3 cases aren't drilled for a dipstick. You can get an adapter from all the usual suppliers though... Image
