Pushrod length
Pushrod length
I am pretty sure that I know the answer to this question but I have to ask anyway to double check myself and be sure. When running 1.25:1 rockers with standard deck height on a non stroked motor you still have to cut your pushrods to length right? to make up for the different "rock" on the rocker...right??
You will have to setup the rocker arm geometry during the mockup build of your engine. Take your time and make sure it's dead on. A properly setup valvetrain will make more HP and improve the longevity of the heads, cam and lifters, not to mention make the engine run much quieter. I use an adjustable pushrod and a soft spring (hardware store) in place of the stock valve spring for setup purposes. This allows you to push the valve down at full lift to check for interference, piston to valve. It is also a little easier to adjust the pushrod as needed. Do this with the head torqued and no pushrod tubes. Once the geometry is correct be sure to test it with the valve springs you are going to run and check for coil bind at full lift before you cut pushrods.
1.25:1 rockers can and will sometimes work with just some rocker stand shimming but if you are building a fresh engine with a new case, heads and cylinders you need to start at square 1 on the valvetrain geometry. Do not take a shortcut on the geometry. I am not a big fan of 1.25:1 rockers, they are typically more difficult to setup and cost the same amount of money as 1.4:1 rockers. 1.4:1 rockers give you more performance for the same money. This link has everything you need to know about setting up VW valvetrains although it is lacking in the picture department a bit. http://www.vdubn.com/sandrailing/engine/valvetrain.htm
