Powder Coating Question
Reverb
Post by Reverb »
I have never in my life used powder coating for anything. Last time I had a project car was back in the 70`s. Is powder coating heat sensitive? In other words, can it be used on exhaust parts?
UncleBob
Post by UncleBob »
No. Ceramic Coating is the way to go for exhaust.
I had my roll cage and accessories pwder coated and my exhaust and anything that resembled chrome I had ceramic coated. Ceramic actually makes it a bit cooler :rock: Gene C
fubar
Post by fubar »
The advantage to powder is that it covers well on complicated parts like tubing and wire mesh. You have to remove anything that might melt, like lead in solder or bearings that might get ruined by sandblasting. ( because of baking temps) Another disadvantage is that touch up are near impossible if you have to modify something or get a scratch..
desbuggy
Post by desbuggy »
Do it yourself powder coating products like those at Eastwood are baked at 400 degrees F. So I would limit use on anything that gets near that temperature. Doug
Doug, do you have a link or other info on DYS powdercoating? I was thinking about buying an oven...
allen pierce
Post by allen pierce »
Thanks Allen. You seen to know alittle ( or alot) abut eveythinng!!!
allen pierce
It may seem that way, but, I'm just organized.
Im goint to try the powdercoat thing. a buddy has an old oven. I already have 20 amps dedicated in my shop for my MIG. so Ill just buy a gun ans some powder and try it!! Heck if it works out, Ill powdercoat all the pieces I spray painted last winter.
