altnator conversion question
Hello all Im converting a gen to alt and im a bit confused, on my old regulator there are 3 wires, 1 b+ going in and two coming out that went to the gererator one of which was grounded to the side of the regulator, I do know that the b+ goes to the batt terminal on the alt, but its the spade terminal im confused about, the D+ wire went to the ground on the side of the reg and then to the gen, does this mean to ground the spade term on the alt? I have no charge light or anything just a voltage, charging guage. Thanks in advance for all your help
This should do it. http://www.nls.net/mp/volks/schem/gen_alt.htm p.s. You'll need to install an idiot light.
