a measurement needed.
:help: I want the measurement from the centre of the end of the rear torsion bar to the centre of the rear hub spindle. The more contributions from members the better. What I'm not looking for is a lot of offerings on how VW suspension works etc. which is what I got on a UK forum when I posted this thread. Some of their ideas are way off and only a single measurement. How else can I put it, I already know a lot about VW suspension without wishing to sound arrogant. What I want is: --ins or --mm. Is there anything wrong with asking for info in this way, am I missing something? regds shaky
41 centimetres on both sides measured along the long axis of the pan. I have replaced the torsion tube rubbers, bearings and seals on the axles, so there is no undesirable movement in the assembly. I have an IRS rear end. The measurement from the end of the axle to the end of the torsion bar tube in a straight line is 42.5 centimetres on both sides. I hope that this helps. I am intruiged as to why you need this information from many of us. Please eventually enlighten us.
Thanks guys and keep up the good work. There is nothing sinister or underhand, even exciting about it. I will post the results (providing we get over two results) right here for all to pick over, criticise or generally ignore. Thanks again shaky I did say on the UK forum that I was going to sell the results on Ebay [FONT=Arial Black]because[/FONT] the only replies I got were people saying that they wouldn't give me a measurement. Paranoid or what!
Mine were approximately 16.5 inches. Its an approximation because I have a swingaxle and the ends of my torsion bars are covered by caps. Really the only way to get an accurate measurement would be to level the trailing arm and remove the torsion cap and rear wheel and drop plumb lines to the floor. If I was concerned about the adjustment of my rear axles, it would really be easier and much more accurate to take it to a shop and have a 4 wheel alignment done. Adjustment of rear toe in is why the spring plates have slots rather than holes. I've never had my wheels aligned so I have no idea whether my rear wheels are toed in or toed out. I believe they're supposed to be either neutral or toed in, so that might mean the proper distance should be toward the shorter end of the adjustment range. However, you definitely don't set toe in by measuring from the wheel center to the torsion bar center. Do you know whether the center to center length of a swingarm springplate and an IRS A-Arm are the same? Are you concerned with manufacturing variations in suspension components or wheel alignment adjustments?
I believe that the swing arm and IRS are the same measurment but am always up to be corerected. I just want a whole bunch of measurements, (which I believe will be quite similar) so that I can get a good average figure. I always set my toe in using thin string tied around the both rear wheels and run forward to the front wheels.
Hey Paul, how did California go? Have you seen this thread on the vzi forum...it's kinda turned into a Buggy message board in its own right, 19 pages and counting!!! :laugh1: http://www.volkszone.com/VZi/showthread ... ge=1&pp=10
