oil cooler ?
oil cooler ?
will a transmission cooler work as a oil cooler?
I was wondering if a oil cooler from a custom Harley my buddy just built would work. It sure looks sweet Second item from the top!! :drool: http://www.tejasthumpcycles.com/Parts/Oil_Coolers/Harley_Oil_Coolers.htm
normal oil coolers really aren't that expensive. I've seen several for around $50 I would personally recommend getting the proper part for the job. You could probably get a frig heat exchanger to work but it wouldn't work as well. Also where do you plan on mounting it? Some people think it's ok to mount it over the fan whole. This is a big no-no! If you think about it all that does is restrict the air flow over the motor and it heats the that air. So oil cooler causing less hot air flow as you can imagine is very bad. Sorry if i got on a soap box there. i've just blone a motor because the PO did that. To make it worse it was a race quality 1914.
