Gas Tank Support Brackets
Its been a while since I removed the front support brackets that go underneath the buggy's front end that supports the stock gas tank and its hold down clips. What I dont remember is how they mount to the front end. It looks like they just drop over the two threaded mounts. Do they bolt down or not. I can take pictures to clarify what im talking about if needed.
When I worked on this Manx for a local couple I fabricated this mount because the person that originally assemblled this Manx decided it didn't need the supports under the gas tank.
The 2 nuts welded on the lower piece of angle have been bored out to fit over the threaded bosses on the front beam. A bolt with a flat and lock washers hold it tight to the beam. You may have noticed that it is made off center. This was done to allow me to use the exsisting fuel tank mounting bolts. The person that originally built this buggy didn't or couldn't read directions or a ruler.
This is what it looks like when installed. You can see a small stress crack in the fiberglass due to the buggy being driven with no support under the fuel tank.
