I have bought the replacement E brake cables and they came with the cables and the sleeve that goes from the chassis to the drum.... Now where do I find the little piece of tubing that connects the sleeve with the chassis tube? Its like a two inch section of tube that links/goes between the chassis exit tube and the sleeve to the drum, thanks!
The outer cable casing should fit over the tube that sticks out the back of the tunnel and the other end of the outer casing mounts to the brake backing plate. I know of no other pieces. The cable/casing should all come as one unit.
So there is no tiny section of tube between the casing/sleeve and the chassis exit tube (the one that sticks out the back of the chassis/frame horns)? Just the casing/sleeve straight into the chassis exit tube?
