what to coat a front beam with
Posted: Wed Aug 02, 2006 7:23 pm
by 90volts
looks like mine was done previously with a por-15 type of junk. just not as durable. are you guys painting it? coating it with something? don't want to pull it out right now just make it more presentable. its black now.
Posted: Wed Aug 02, 2006 8:28 pm
by fubar
You can brush or phizz can Hamerite right over dirt, mud , and insects with pretty good results. Home Depot sells it.
Posted: Wed Aug 02, 2006 9:55 pm
POR-15 is as durable as you are going to get as far as paint is concerned. POR-15 is nearly as durable as powder coating. Prep the surface as directed in the POR-15 directions and apply the POR-15 and it will last longer then 99% of the paint you will find.
Posted: Wed Aug 02, 2006 9:57 pm
I blasted and painted mine with Rust. satin black. still looks good.
coat front beam
Posted: Wed Aug 02, 2006 10:49 pm
by joemama
I use Hammertone by Rustoleum, goes on good, even if not perfectly clean, and pretty tough by paint standards. If you are going to flat tow with towbar that rides on the front beam, you will want to be able to touch up easily.
