carpet question
Posted: Wed Dec 06, 2006 7:24 pm
by tat99
my manx is complete and i wanted to put in one of those new carpets. can this be done with the body left on , maybe just lifting it a little. and can that be done with not much disassembly. has anybody done this? thanks
Posted: Wed Dec 06, 2006 8:07 pm
by Mr Towd
Yes, just unbolt it and tuck it under. Check out the free carpet thread.
Posted: Thu Dec 07, 2006 6:25 am
by bountyhunterdm
Can I just install it over the flange around the inside of the body? Mine is not only bolted but sealed with silicone. Also I gues I should call you to find out how I go about measuring for a kit.
Posted: Thu Dec 07, 2006 1:57 pm
by Mr Towd
You, can mount it over the flange but it will have to be finished off. They will fit any buggy shortened 14 1/4" or full length. If you need any further help please give me a call as I do not want to use this forum as a sales tool.
Posted: Sat Dec 09, 2006 9:15 pm
by bountyhunterdm
Sorry You're right my BAD I'll give you a call..
Posted: Thu Dec 14, 2006 2:21 am
by JThw8
Definitely get the Tijuana Customs kit. It is wonderful. I just had to lift the body enough to tuck it under the edge. I suppose you could trim it back and not lift the body at all if you wanted. My full install with photos is here if you wanted to check it out
http://www.misfittoysracing.com/Manx/ca ... /index.htm
Posted: Thu Dec 14, 2006 5:02 pm
by Olli
With a Manxter, you can install without unbolting/lifting the body. I just trimmed and tucked the carpet under the body flange. Excellent fit! Olli
