Inside the Tunnel
Posted: Sun Jan 12, 2014 1:27 am
by Ed-Chenal
These cutaway pictures of a VW type 1 Bug tunnel have made the circuit before but you may want to add it to your favorites list for future reference.
http://www.vwdcqinc.org.au/insideabug-i ... ug_63type1
Inside the Tunnel
Posted: Sun Jan 12, 2014 2:31 am
by Scott-Drolet
I hadn't seen that before Ed. Very cool. Thank you for posting it!
Inside the Tunnel
Posted: Sun Jan 12, 2014 2:59 am
by FulsGld
Very nice. Now I know what's going on inside there. Thanks Ed...
Inside the Tunnel
Posted: Sun Jan 12, 2014 3:49 am
by manxvair
That's pretty cool!
Re: Inside the Tunnel
Posted: Thu Apr 03, 2014 2:41 pm
by Tom-Szwajkos
I have an access plate on the right side of the tunnel opposite the clutch hole. It is a 4"x6 inch opening that is reinforced with 1"x 1/4" steel. It makes it a lot easier to access the clutch and brake pedal linkage. I installed Morse push/pull throttle and clutch cables in the tunnel and needed this access port to hook everything up. The cool thing about the clutch cable is that it is 3/16 diameter cable with an outside jacket. I never have to worry about breaking it. Same size that is on Kenworth truck. Went overboard because I did not want to deal with broken VW clutch cables and the Chevy Corvair clutch. I run a Corvair tranasaxle and Corvair engine utilizing a Hadley conversion kit.
Posted: Tue Jan 20, 2015 4:50 am
by Bradspurplemanx2
I got a first hand look at mine when the clutch cable tube crossmember bent and broke away from its mounts in the tunnel. Good times. Great Pictures.
