Mastercraft A/T Tires
Posted: Tue Jun 01, 2010 2:54 pm
Anyone running Mastercraft A/T tires on their buggy? If so how does it ride? What PSI are you running? And how is the noise on the highway?
Thanks,
--louis
Thanks,
--louis
https://mail.manxclub.com/forum/
Tire Size Item # Load Index / Load Range Speed Rating Sidewall Tread Depth (in 32nds) Runflat Tech Features Fuel Effic Features Tread Marking UTQG Tread UTQG Traction UTQG Temp Revolutions Per Mile More Max Load, Single (@PSI) Max Load, Dual (@PSI) Overall Diameter Rim Width Range (Min/Max) Section Width (On Measuring Rim Width) OE Marking (Sidewall) OE Code Additional Features Side (Left/Right) P205/60R13 54986 86 S RWL 11 916 @ N/A 22.7 5.5" - 7.5" 8.2" P205/70R14 66748 93 S RWL 12 400 A B 819 1433@35 N/A 25.4 5" - 7" 8.2" P215/60R14 98659 91 S RWL 11 400 A B 860 1345@35 N/A 24.2 6" - 7.5" 8.7" P215/70R14 50228 96 S RWL 12 400 A B 803 1554@35 N/A 25.9 5.5" - 7" 8.7" P225/60R14 53273 94 S RWL 11 400 A B 842 1455@35 N/A 24.7 6" - 8" 9" P225/70R14 79604 98 S RWL 12 400 A B 785 1675@35 N/A 26.5 6" - 7.5" 9" P235/60R14 79644 96 S RWL 11 400 A B 829 1565@35 N/A 25.1 6.5" - 8.5" 9.5" P245/60R14 54322 98 S RWL 11 400 A B 813 1675@35 N/A 25.6 7" - 8.5" 9.8" P155/80R15 86745 83 S RWL 12 400 A B 842 1069@35 N/A 24.7 4.5" - 5.5" 6.1" P195/60R15 64472 87 S RWL 11 400 A B 860 1190@35 N/A 24.2 5.5" - 7" 7.9" P205/60R15 71072 90 S RWL 11 400 A B 842 1301@35 N/A 24.7 5.5" - 7.5" 8.2" P215/60R15 67797 93 S RWL 11 400 A B 825 1411@35 N/A 25.2 6" - 7.5" 8.7" P215/65R15 78624 95 S RWL 10.5 400 A B 800 1510@35 N/A 26 6" - 7.5" 8.7" P215/70R15 72634 97 S RWL 12 400 A B 773 1620@35 N/A 26.9 5.5" - 7" 8.7" P225/60R15 64148 95 S RWL 11 400 A B 813 1521@35 N/A 25.6 6" - 8" 9" P225/70R15 67244 100 S RWL 12 400 A B 759 1753@35 N/A 27.4 6" - 7.5" 9" P235/60R15 54712 98 S RWL 11 400 A B 797 1642@35 N/A 26.1 6.5" - 8.5" 9.5
