Fan belt not vertical
Posted: Tue Jun 17, 2014 10:41 pm
by Stewart
OK....I replaced the broken generator pulley with a new empi pulley and its not vertical, I shimmed it out with washers but still not quite vertical, its a Porsche generator, any ideas?, can I just slide the whole generator aft?...I already added 2 washers between the generator and the pulley, can't put any more because of the keyway and 2 shims in the pulley, thanks
Re: Fan belt not vertical
Posted: Wed Jun 18, 2014 1:21 am
by Ed-Chenal
The store may have sold you a horizontal instead of a vertical fan belt.
The horizontal belts are only used on VW aircraft engines.
Unless you plan to go airborne, I wouldn't use it.
Posted: Wed Jun 18, 2014 9:15 am
by Tom-Kathleen
You can take the crankshaft pulley off and machine a little off of the surface that seats on the crank, but not so much that is will hit the case. Measure the clearance before you try this. Tom
Posted: Fri Jun 20, 2014 1:59 am
You need to use a 6v generator pulley to us on your Porsche size 12v generator.
A 12v pulley has the wrong spacing since a regular size 12v generator is longer.
Posted: Tue Jun 24, 2014 12:35 am
by Stewart
6 volt pulley......Cool, Until I get one I picked up a CB Performance generator shim kit and shimmed it out, Good for now, Thanks everyone for your input......See you at Big Bear !
