Engine Tin--What's Required
Posted: Fri Oct 23, 2020 11:02 pm
by papya
What pieces of engine cooling tin can I do away with on my Manxter?
Obviously the curved rear piece is not required. What about the front piece that goes between the case and the body?
Also what about the down piece from the doghouse cooler?
Left and right under cylinder rear deflectors?
Re: Engine Tin--What's Required
Posted: Mon Oct 26, 2020 4:52 pm
by GotManx
I usually just run the shroud and the cylinder tins. Make sure the deflector tins under the cylinders, above the pushrod tubes, are in place.
Posted: Tue Oct 27, 2020 4:21 am
by papya
GotManx wrote:I usually just run the shroud and the cylinder tins. Make sure the deflector tins under the cylinders, above the pushrod tubes, are in place.
Thank you.
