brake cables
ralphdjeeper
brake cables
Hi all i need the correct length for the handbrake cables, and the brake cables also for a 1964 Meyers Manx ? thanks for any help ralphdjeeper
ralphdjeeper
ralphdjeeper
Yes cairoManx thanks that is what i ment to say its a 1964 pan it sits on., and thanks for the quick reply. ralphdjeeper
Double check that length. Due to the multi year set up I was too short. (I was running a 63 pan with a 68 Long Axle swing arm and that extra few inches did me in. SInce the cable stretching machine was unavailable. I had the opportunity purchase new and have them shortened again. I may still have them. They could be yours If I still have them. Carlton
Really, the only accurate way to get the length that you need is to fit the long cable and mark it to the length that you need. There are too many variations possible to be certain that a measurement off the car will do it. I had a set that was 1 inch too short on my buggy. They worked well but getting them to fit was a pain.
