Manx II #1493 Build
Manx II #1493 Build
lol I wish. I have a couple of weeks off starting this week so I plan to get some serious work done, God and wife willing. Pan and suspension parts are all ready to go to the sand blasters, just waiting on the funding to appear. Then it will be time to get it rolling. I will probably start back on the fiberglass work this week. Thanks for asking.
--louis
--louis
Manx II #1493 Build
I'm seeing some really nice work going on here. Keep notes and pictures and submit a build story for the Manx Mania. Lot's of folks who don't follow you on this site would love to see your work and get tips for their builds. You are keeping the dream alive......
Bob
Bob
Manx II #1493 Build
Thanks for the comments Bob. I will be the first to admit that I am not an expert and I have borrowed or adapted most of these ideas from other people. I have had a lot of help from other veedubers over the years and would be happy to pay it forward as an overview or tech article. The cars may be the focus of our hobby but its the people you meet that make it great.
Thanks,
--louis
Thanks,
--louis
Manx II #1493 Build
For kicks and giggles I decided to mock up the buggy with the new rims & tires to see what it would look like. I was a little concerned that the front tires were too wide for the look I want but I am happy with them now that I see them up against the buggy. I may go a little lower than this in the end but not too much. I still have not been able to get the rear tires to seat correctly so I may end up taking them to the tire shop.
--louis
--louis
Manx II #1493 Build
Looks good,,,, If you can,Break the bead,,Soap the rim up Real good with dish soap,,Take out the valve steam and hit it with a 100+ lbs of air,,It well seat,,,,Tire paste is better,But soap well work,,,,Note,,When it dose seat,,It's gonna make a loud pop,,,,
Manx II #1493 Build
That sounds like a good way to get the tire bead to seat on the rim but I think you want to remove the valve core which is inside the valve stem.[b]10ovr[/b] wrote:Looks good,,,, If you can,Break the bead,,Soap the rim up Real good with dish soap,,Take out the valve steam and hit it with a 100+ lbs of air,,It well seat,,,,Tire paste is better,But soap well work,,,,Note,,When it dose seat,,It's gonna make a loud pop,,,,
Manx II #1493 Build
My Bad,,,I meant core,,Thanks EdEd Chenal wrote:That sounds like a good way to get the tire bead to seat on the rim but I think you want to remove the valve core which is inside the valve stem.[b]10ovr[/b] wrote:Looks good,,,, If you can,Break the bead,,Soap the rim up Real good with dish soap,,Take out the valve steam and hit it with a 100+ lbs of air,,It well seat,,,,Tire paste is better,But soap well work,,,,Note,,When it dose seat,,It's gonna make a loud pop,,,,
Manx II #1493 Build
Your suggestion reminded me of my youth. I spent six years working at two Chevron Dealers in SoCal during High School and College. Only the Lord knows how many car and truck tires I fixed/changed. Both gas stations were located in the vicinity of Newhouse Automotive, a popular after market retailer. Guys would buy chrome or spoke wheels for their cars and have us swap them out. For several of those years, we did the whole job without the aid of a pneumatic changer. To make the tires slide on easier, we used some stuff called "Rubber Lube."
Manx II #1493 Build
That is pretty much the method that we used to seat the front tires but the rears are not cooperating. They may be a little too wide.
Thanks,
--louis
Thanks,
--louis
Manx II #1493 Build
Been working on the fenders over the past few days. Got one sanded down and the other ready to be sanded. I still need to do a little shaping and some more filler before they are done.
Passenger side ready for filler and final shaping:
Grinding down the driver's side before laying 'glass.
Waiting on it to dry:
It has been raining non-stop here for several days and the temp is up in the '90s. I have been trying to work on it early in the morning before it gets too hot. I am so ready for fall.
Thanks,
--louis
Thanks,
--louis
Manx II #1493 Build
Louis can you come over show me how that is done i have never messed with glass work before, you make it look easy. My buggy looks like the same color as yours. Gary1719
Manx II #1493 Build
Hi Gary,
I use West Marine's epoxy fiberglass system for all the repairs. If you go to their website they have some nice tutorials on how to use their system and it is pretty fool proof. I will say its not cheap though. I save a little money by buying my matt and cloth form the Meglomart.
--louis
--louis
Manx II #1493 Build
I have been down for the past week with a major sinus infection. That and the fact that we have had 100+ temp and 98% humidity for the past couple of weeks means I didn't get anything done last week. But if I go too long without working on the Manx I feel like a bad parent so I sucked it up today and spent a couple hours sanding on it. Got the driver's side fender roughed in and most of the Passenger's side fender filled and sanded.
I also started dealing with this issue. As you can see the lip does not line up correctly with the top hat. I drilled a hole in the front and put in an eye bolt backed with a fender washer. Then hooked up the come-along and started stretching it. I used the halogen lamps in the bottom of the picture to add a little heat as well. It seems to be working but it's not where I want it just yet.
Time for a beer.
--louis
Time for a beer.
--louis
Manx II #1493 Build
Louis are you stretching that into shape with the comealong?
Manx II #1493 Build
My body was so twisted from sitting on a bent frame the I had to use a propane heater and stretcher bar to get it back in shape,,,The more heat the better,,, Looken good buddy,,,,
