rear seat
The usual back seat in a manx is just a couple pieces of plywood padded with foam rubber and covered with vinyl or fabric. People used to attach them with screws from the underside, but its much better to just use some heavy duty velcro. You'll need to make a paper or cardboard template pattern of the bottom and rear of your back seat area, then transfer it to the two pieces of plywood (3/4" thick). Leave enough of a gap around the edge of the plywood for the covering to fit. The best thing would be for you to cut the two pieces of plywood and take them to an upholstery shop and tell them to make up covers that match your front seats.
Reverb, Pretty much identical advice, That's funny. I really like the velcro though, I hate drilling holes in my fiberglass. The other thing I do is have the two little ears on the front edge of the seat extend wide enough so they tuck in behind the rollbar. That way the rollbar also holds the seat bottom in place.
Notme, Here is another option. Scroll down to the last seat on this page. They are a good outfit and a manx club sponsor. http://www.prpseats.com/suspension-seats.html
Neal from Texas does custom rear seats... http://hometown.aol.com/lonestarbuggy/page5.html ...or I cut my own (3/8") boards and covered them using vinyl and foam sewn up by Mel Hubbard's wife. Held in mainly by double sided badge mounting tape.
My back seat area has the cut out for the spare tire and the battery box, so it needs plywood over it in order to use as a seat. However, I bolted down the plywood to the body, and just the cushion velcroes to the plywood, this way I can remove the cushion and still have a flat area to carry things. Also I strongly suggest you waterproof the plywood you use.
[QUOTE="joemama"]My back seat area has the cut out for the spare tire and the battery box, so it needs plywood over it in order to use as a seat. However, I bolted down the plywood to the body, and just the cushion velcroes to the plywood, this way I can remove the cushion and still have a flat area to carry things. Also I strongly suggest you waterproof the plywood you use.[/QUOTE] Good point. I forgot to say I used marine quality ply wood.
I had the chance to work with a product known as "Starboard". It is a polymer sheet used in building boats and boat interiors. I plan on using it for the seat bases on my Siggy Manx. It won't delaminate like plywoods and is basically unaffected by moisture not to mention quite rigid. Take a look and see what you think. http://www.kingstarboard.com/Products/starboard.aspx
