New dash panel??'s
Post by manxdavid »
[QUOTE="Lee"]I bolted my side pods on by using the flanges on the leading and trailing edges. This required drilling through the body. Two bolts at each end for each pod is all it took. I didn't want to bolt them at the bottom, as I didn't want anything sticking down. Nuts or bolt heads can get hung up on rocks. I guess I'm not as timid about drilling holes in my car as I should be. [/QUOTE] I mounted mine the same way using two M8x30 bolts at either end. I did put a bit of 'push-on' type body edging over the raw fiberglass edges in case of and possible squeeks.
