Brake Parts
Brake Parts
I just found out, that the link pin beam I have is older than I thought. The wheel cylinders have 4 mounting bolts. I`ve been told those are pre 1953, and unavailable. Does anybody know if the backing plates for a newer link pin beam will fit on this antique?
I cant say I know. but I bet it would be easy to find out or even just modify what you have to work with new cylinders. maybe it is a good time to go with disk? I have a 59. and it has 3 bolts to hold on the backing plate I believe. I can get some measurements if you like. it is on the buggy so who knows how accurate it will be. guessing at 2 1//2 from top to bottom and 4 1/2 from front to rear? I did not me sure just looked at.. the one bolt is in front and 2 bolts in the rear.
[QUOTE="Reverb"]I just found out, that the link pin beam I have is older than I thought. The wheel cylinders have 4 mounting bolts. I`ve been told those are pre 1953, and unavailable. Does anybody know if the backing plates for a newer link pin beam will fit on this antique?[/QUOTE] I thought those early wheel cylinders were 2 bolt fixing
either way i can see no reason why you cant fit later (link pin) backing plates. Im sure i came accross this problem years ago,,,, but like the hair,,,my memory is going
