dirty gas tank
dirty gas tank
I have a lot of crud coming out of my gas tank, collecting in the inline filter. Pretty sure it's old rust. Any suggestions on cleaning the inside of the tank without removing it. Thanks, ron
There is a fine mesh screen in the bottom of the gas tank at the hose fitting that sometimes gets damaged or removed. If the tank isn't too rusted it will capture most of the flakes, though it will not filter out the small stuff, thats what the filter is for. If the tank is badly rusted the screen will just clog and starve the engine of fuel. If you are a patient person, or have access to some little hands the screen can be serviced without removing the tank.
Lots of how to articles on Google. Can be done without removing tank. Use a bare steel wire as an anode. Put it in through the filler. Slip short sections of rubber tube over it to act as insulator at points it would contact inside the tank. It will actually do a better job than mechanically agitating. Search: http://www.google.com/search?hl=en&safe ... tnG=Search
