Catepillar Exhaust Paint
Olli
Post by Olli »
I have also use the CAT hi heat paint with excellent results. I bought it direct from a CAT dealer. Fram has been tested as one of the worst filters available. Wix, Hastings, Purolator, Motorcraft are all much better. Olli
[QUOTE="manx4dan"]Thank you both, I'm going to first pursue the prefab hoses (I think 22" should work out great). Contrary to your Warning (again): Do not use any standard duty oil filter (like PH8A) on a VW air cooled engine in full flow. Use only filters that have at least the burst rating of the Fram HP1. I've been using the PH8A filter for atleast the last 2 years and am unclear what the issue is. Are you saying there is back-pressure? That could explain why my hoses seems like they're oozing a little oil. If that's the case I'll switch to the HP1 instead.[/QUOTE] If you have oil oozing from the hoses there is a problem with the hoses, not a backpressure problem. What I was trying to say was....Not only does the Wix filter out filter the Fram filter, the Wix will not burst like a conventional filter under excessive pressure. My sandrail, Manx and Baja all run about 125psi when the engine is cold and in the 10 years I have been using Wix filters they have never failed. Why pay all that money for the Fram?
If you can't find Wix at your FLAPS, try Napa. As I recall, Napa filters are made by Wix.
