Stock head studs
jr_vw2
Stock head studs
Post by jr_vw2 »
How strong are the stock 1600 8mm head studs?? I am building a 1915 with an engle 110 cam 1.25:1 rockers 044 big valve heads (40mm X 35.5mm) and will be running dual 40mm carbs. My questions is this.... are the stock head studs going to be strong enough? Or should I go to a set of chromolly studs. Thanks guys.
michael cook
Post by michael cook »
I just bought a 1915 from a guy who builds them in calif he puts the c-moly says they are needed hope this helps mike
All the engines I build run with stock German VW studs. I am running my personal 1914 with stock VW studs and haven't had any problems. I don't think there are many people out there that abuse an engine much more then I do. :roll:
joemama
Post by joemama »
1914, 110 engle, stock dual port heads, stock rocker arms on heavy duty shaft, lightened flywheel, 009 with compufire, chromemoly pushrods, single Zenith 32 carburetor, AND stock 8mm studs. Never a problem. Have heard that the 8mm studs are preferable to the 10mm because they expand and contract at a closer rate to the case, cylinders, and heads.
Anyone heard of case savers?? Jimbo
jr_vw2
Post by jr_vw2 »
Case savers are kind of like helicoils IN that they are solid threaded inserts that you put in your case so the studs are not threaded into straight aluminum.
jsturtlebuggy
Post by jsturtlebuggy »
The stock factory 8mm head studs worked great for most purposes. They expand and contract with the cylinders and heads. Using chromoly there is no expansion so cylinder starts cutting into case and head and head nuts come loose. Chromoly works for high compression short term (rebuilding after a race) engines.
[QUOTE="lsjimbo"]Anyone heard of case savers?? Jimbo[/QUOTE] I wouldn't waste my time building an engine without case savers.
