rear seat
I have "Starboard" on my boat, and like the easy maintenance. There is a panel that I have to remove for engine maintenance,it is held in place by oval head sheet metalscrews, and after removing and installing 3 times, all the screws have pulled thru the Starboard. I dont think it has the same structural strength of plywood.
[QUOTE="mel hubbard"]Im trying to post two more pics of that buggy to ya Dave, but you know what im like on these things,,,it wont send,, maybe later. That orange is a popular choice,, you should start up the Tropicana buggy club UK Dave :laugh1:[/QUOTE] You know when you've been Tangoed!!!! :laugh1:
Mounting Starboard is supposed to be done with threaded inserts. Sheetmetal screws are probably the worse thing to use in Starboard, because of the tapered threads and the fact that they try to cut new threads each time they are installed. I have tapped holes in Starboard with a 1/4-20 tap and mounted a Lowrance unit to it in my friends 42' Fountain that gets removed and reinstalled every weekend during the summer and he has not had a problem in since I installed it 3 years ago. It was supposed to be a temporary thing until I installed threaded inserts, but why mess with a good thing.
I think it makes a difference if you have battery and spare wells or not. If your back seat is flat all the way across, 3/8" is definitely thick enough. However if it has to span the wells and there is just a narrow ledge of fiberglass for the seat to rest on, on the driver's side, I'd be worried about a big passenger stepping up on the tire, then onto the backseat and it bowing or splintering. I use 3/4" for the seat bottom but it might be overkill.
More pics of Mel H's mate's Sidewinder Buggy...
Awesome is a much overused word these days but I think it fits here!!! :2cents:
[QUOTE="mel hubbard"] Dave I still have a very nice hologram flake over black S/winder here with your name on [/QUOTE] Sounds like you need a stall at Dubfreeze Mel and a Sat. night out in swinging Stafford!!! http://www.dubfreeze.co.uk/
[QUOTE="Manxdavid"]Sounds like you need a stall at Dubfreeze Mel and a Sat. night out in swinging Stafford!!! http://www.dubfreeze.co.uk/[/QUOTE] If the Kubelwagen is done by then I will go,,,and take both. Also its the Essex Hot Rod swap meet March 3rd,,, You going?? My buds hoping to take his 56 Chevy truck 454ci,, its a real beast,,monster fast n real REAL clean,, its orange too, with flames,,you will luv it
